configure policy convergence-endpoint index
configure policy convergence-endpoint index index [cisco | lldp-med]
Description
This command sets a global default policy index for a Convergence End Point (CEP) detection type. This policy is applied when a phone of the specified type is detected on a port.
Syntax Description
index The policy index to apply. Use 0 to clear an index.
Note: After CEP devices are mapped to a profile, changing the index value to "0" or to some other policy profile name, the existing CEP connections are still be mapped to the old profile that was configured initially when the CEP devices were detected. To force a refresh of existing detected devices, disable, and then enable, CEP (see configure policy convergence-endpoint) or disable, and then enable, the port(s) (see disable port and enable port).
cisco Specifies Cisco type CEP.
lldp-med Specifies LLDP-MED type CEP.
Default
N/A
Usage Guidelines
The corresponding policy must be configured using the policy management commands (for example, configure policy profile).
The following example applies as default the policy associated with index number "12" to Cisco type CEPs.
# configure policy convergence-endpoint index 12 cisco
This command was first available in ExtremeXOS 22.2.
Platform Availability
